Topic: Rear brake hose part #? (Read 2282 times) previous topic - next topic
I need to replace my rear brake hose and auto parts stores are giving me fits.  I need the brake hose that connects the rigid brake line on the rear axle to the rigid brake line on the chassis.  It's only common sense that there would have to be a flex point for the brake lines.  Anyone have a part # for that hose?
William
I'm still looking too if i find it I'll post
turbo coupe rear end with discs or a drum brake rear ??
Disk brakes.  :)
William
give me a little bit , I'll see what I can find
http://www.rockauto.com/catalog/moreinfo.php?pk=304511
http://www.rockauto.com/catalog/raframecatalog.php?carcode=1140208&parttype=1792
1987-88:
TURBO COUPE: CENTRIC Part # 15061322 Brake Hydraulic Hose, Rear Disc brakes; Rear Upper
V6, V8: RAYBESTOS Part # BH36829  {#4536829} R Brake Hose w/FT DISC/RR DRUM,EXC 2.3L - TURBO 13" OAL REAR CENTER
http://www.rockauto.com/catalog/raframecatalog.php?carcode=1140231&parttype=1792
Those are part#'s for the CENTER, rear brake hose Eric (the one directly above the pumpkin)?
William
Here's the one from the rear end I'm rebuilding out of am 87 turbocoupe. I can't find one that does it like this
Wagner part number F113929 is the one our Massachusetts friend has pictured .
Quote from: 88 Blackbird 5.0;379284
Yes, for the Turbo Coupe it's listed as the rear upper.
Looks like you have a few part numbers now...hopefully one of them works for you.
H38387 ..... I found this as a dorman number too
Thanks for the part #'s guys.  I appreciate it!
William
