Topic: 5 lug spindle swap (Read 1680 times) previous topic - next topic
5 lug spindle swap
I've seen alot about SN95 spindle swaps. I'm curious if there a difference in V6 and V8 spindles? I'm sure I'll catch some flack for asking but you never know if you don't ask. Thanks guys for any info.  :toilet:
5 lug spindle swap
I hope not I'm using v6 spindles. I was under the impression they were all the same, GT ,V6 OR COBRA
5 lug spindle swap
the V6 and GT parts are the same. As far as Cobra...I know the brake parts themselves can be, and usually are different, but I *think* the spindles are the same for those.
5 lug spindle swap
spindles are the same, i have "cobra" spindles.
reason why
me and a friend found spindles and front brake set up for a 95 cobra, his bro had a 96 GT, he use the brake components and gave me the cobra spindles and his gt brakes as a finders fee. its whats on my car now... the brake heat shield is an inch bigger then my rotors now, lol.
Brian J Larkin
1988 Tbird Turbo Coupe
1989 Cougar XR7
1995  Ranger Splash
5 lug spindle swap
Sweet a local guy is parting out a 98 and I was gonna rob the parts. I even thought of taking his stock 6cyl rear just so I got matching bolt patterns.
5 lug spindle swap
Just pull the axles. The 7.5 is used either way, and his rear brakes and axles would be easier to work then the whole rear end.
5 lug spindle swap
Yep...and, if you ever locate an 8.8 rear, you can use the 5 lug axles in the 8.8 housing. The axles are the same, 7.5 vs 8.8, in regards to 94-98 Mustangs.
