Topic: Seat Bracess For Global West Sub Frame Connectors (Read 23807 times) previous topic - next topic
Reply #60
Thanx alot Brian it is true we appreciate your effort
Reply #61
havent herd from Paul so i will be calling him tomorrow and see if he has spoken with the owners or something to set up a date will keep you guys posted
Reply #62
Just a note that GW builds round tube full length sub-frame connectors and the seat braces are made from angle iron or at least that is how they build the ones on my Coupe.
Darren
Reply #63
talked with Paul at global west said they're swamped at the moment so it might be a few days till they give me a call
hey Darren, is angle iron good or bad?
Reply #64
The way they use it to brace the rear mounting point of the seat brackets in the Mustangs loads the angle iron in a manner that plays into the strength of the angle iron.  Always a plus when a manufacturer actually utilizes the design of materials to their benefit.
If you want I can get a shot of them installed on my Coupe so you can see how they are installed.  Granted it will be different with the T-Birds or at least on the 83-86 cars (I have no idea how the seats are attached at the rear mounting points on the 87-88 cars) as there are mounting studs versus the Mustangs which utilize bolts.  My best guess is that we will have to cut the studs off with a cutting wheel or the like and then center punch the studs and drill them out to convert over to the bolted style to make use of the seat brackets.
Darren
Reply #65
Quote from: Aerocoupe;388555
I've removed the studs with a little head and a stud extractor (they're just screwed in).  You could weld a nut to the upper part of the stud and remove it that way too.  Then replace with bolts.  One is an M8x1.25 and the other an M12x1.75 (vs the M10x1.5 in the Mustangs).
Reply #66
Problem solved and learn something new every day.  Thanks for the info Chuck!  This info needs to be passed on to GW if they come around and hook us up with the seat braces.
Darren
Reply #67
any update on this one guys?
Reply #68
If it is still possible, could ya'll count me in on this one.  I could use a set of SFC and seat braces.
Reply #69
Quote from: 1986Élan;389848
No updates yet.  Last I heard, Base was waiting to hear back from Paul at Global West on a date to take his car to them.
William
Reply #70
Quote from: edgar_g1;389969
You're not too late Edgar.  We're all waiting to find out what Global is gonna say about making the seat braces still.
William
Reply #71
Should we start call GW and inquiring about this?
Darren
Reply #72
I'd say the more of us that call Global (ask for Paul) and tell them we want seat braces, the better.  1-877-470-2975.  Call him!
William
Reply #73
Base...  Has Global told you when to stop by yet?
William
Reply #74
no i havent goten any calls from GW or Paul
