Topic: help with DC electric motor (not in Cougar) (Read 1473 times) previous topic - next topic
Hi-  I purchased this DC electric automotive fan motor to use for a display turntable.  I also got a PWM speed controller for it.
http://www.surpluscenter.com/item.asp?item=10-PM508&catname=electric
Whenever I bought an electirc motor in the past it had two leads.  This one has a just a little silver pin sticking out of it.    I'm pretty sure the silver pin should go to the positive lead on my 12v DC power supply,  and the negative lead from my power supply should attach to the motor's metal casing.    any ideas?    Thanks!
see pic of connector
Well, to use a brushless motor with a pulse width modulation speed control, you would need at minimum 3 wires. All 3 should be powered and pulsed sperately. The way a pwm works is by automatically controling which part of the motor has power to keep it moving in the right direction, and speed. You have either the wrong motor, speed control, or wires going to the motor.
this one doesn't have dual windings.  just a single speed 2000 rpm motor.    The PWM controllers I've seen (not industrial but  more hobby / robotics oriented)  require two leads for power input,  12 volts in this case,  and have two leads for output.  the speed is controlled with a dial from 0 to 100%.
I see. I have almost always seen the pulse's sent between three wires going into the motor. Take 12v to the two leads and see if it spins.
Did you clean a bare spot for the ground? won't ground to a painted surface. Should work direct the way you describe, unless it's a bad one.
