Topic: 1986 XR7 351 turbo swap.... (Read 115047 times) previous topic - next topic
Reply #165
Ok....finally spent 6 hours working on the XR7....
Cut the inner passenger side fender so I could install the intake pipe from the IC to the throttle body....had to use a 3" pipe extension to get the intake pipe to fit....I have no EGR block....
Also figured out that I miss placed my upper intake bolts....grrrh.  Its getting there.
Also installed the 5point8 emblems..... :)
Travis
Reply #167
Last couple of parts ordered....
Mustang 75mm egr spacer....so I have something to plug my throttle cable into...LOL
Lokar ED-5005 dipstick....as the one of got off a guy 2 years of the corral wont work....grrh
3.5" V-clamp and flang...so it can be welded to my small exhaust system.
02 bung....so I can well it in...
New Bosch wideband sensor for my old LM1....as the current sensor is very old.
with that stuff installed....just need to prime and start....almost there....hehe
Travis
Reply #168
Another 6 hours spent....getting dang close....
Going to spend another 3 hours tomorrow. ...
Travis
Reply #169
3 hours because that's all the time you need to finish it up, right?  Keep digging, looking forward to some photos or even video. - Joe
Reply #171
It only took 12 different belts...but finally found the right one....LOL
Travis
Reply #172
OK Gentlemen....
The last two things have been ordered.  Some 1G to 3G alternater wiring upgrade made for a 85 mustang.....then a B&M shifter cable, I missed placed the stuff I used to use.....grrh.
But everything else is done....like everything.  She is ready to start.  Brand new motor, turbo kit, Pimp engine management....
Excited....
Travis
Reply #173
Video!! Video!! :banana: Video!! Video!! :banana: Video!! Video!! :banana: Video!! Video!! :banana: Video!! Video!! :banana: Video!! Video!! :banana: Video!! Video!! :banana: Video!! Video!!
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Reply #175
Ok fellow nutz
I got the shifter stuff mostly worked out...I now need to install my 1G to 3G adatper stuff I bought for $30.  Then it should start....crazy 3+ years...
I have realistically today and tomorrow....the snow is coming and it needs to be inside...
Travis
Reply #177
:popcorn:
Reply #178
OK guys....shifter and 3G all done....lots of copper wire 4gauge, but the 1g to 3g mustang adapter setup is the way to go on the 86 and older fox cats/birds....easy peasy, directions are perfect.
went to try to start, some smoke off the pos battery terminal.  Then I could no longer talk to the Pimp computer....grrh.
Travis
Reply #179
So the big cat is in the garage.  Working on the Pimp to figure out the problem.  So it now it is quiet time until nice weather in Michigan.....so May....LOL
Travis
