Topic: 1986 XR7 351 turbo swap.... (Read 114462 times) previous topic - next topic
Reply #136
Well getting to the home stretch...so I have made a list...
Please feel free to edit...
1. Install alternator...on driver side if I can...I have 3 alternator kits....its a 3G...let see if I can get that done.      DONE
2. One of the mounts for the wastegate needs to be ground down abit...not a big deal so I can finish the WG install  DONE
3.  Install ECT, ACT, temp gauge on dash....install or adjust factory 2.3T wiring  DONE
4. Finish making the injector harness...DONE
5. V8 Throttle cable needs to be installed, possible rehookup of the cruise control...if possible  CLEANED AND PAINTED...NOT INSTALLED  DONE
6.  Install Autolite 103 plugs gaps at .030 and wires (stock motorcraft)  DONE
7.  Install starter.  DONE
8.  Need a plug for the rear intake plug for the heater core, no heat this year...any idea on the size?  DONE....ITS 1/2 NPT
9.  finish vaccuum lines for the intake, FPR, wastegate, BOV and such
10.  Finish C4 shifter install.  Its a modified stock C3 shifter...looks stock.  DONE
11.  Install or make new tranny cooler lines..DONE
12. Install Exhaust 02 bung in the down pipe
13.  Break in oil and 94-95 Cobra oil filter    DONE
14.  Install battery test all Megasquirt sensors...START...
This is the list I currently have...there is lots more to do after the car runs for a bit...aftermarket tranny cooler, more exhaust...deep cleaning...installing the 5.8 badges :)
Add to the list if you think its important for the first start...
Thanks,
Travis
Reply #137
Well an update....
Got some wiring done.  More sensors in the intake.  Still having problems with the drivers side alternator setup.
I got a plan now...well I think I do anyways....
I have to get a different dipstick tube...mine is wrong...grrh.
Man I hope this cat runs by August...
Travis
Reply #138
Quote from: turbotrav;417871
Well an update....
Travis
I feel your pain!
Reply #139
Some updates....family, work, and summer time have delayed this project...but such is life...
Finally got the alternater mount good...cleaned up my V8 throttle cable for future install...did the driverside plug wires...started some wiring...getting closer..
Travis
Reply #140
Very cool ........ Love the car
Reply #141
Quote from: STANG8U;419243
Me too....my children will berry me in this car!
Travis
Reply #142
true car guy!! lol
Reply #144
Alrighty....the final stretch....
Got all the wiring done besides the fuel injector harness....Its amazing to me how 95% of the original 2.3T harness works...
Im going to have to cut the passenger fender area where the original air box was...I cannot get the final intake pipe to fit....with the turbo in place....grrh.  I did test fit the intake/TB pipe last year, but the turbo was not installed yet... Oh well.
Got the alternator mounted...looks like the belt is only going to cover 120 degrees on the water pump pulley.  I have an electric one somewhere, if it doesn't work as expected.
Also got the coolant overflow bottle installed on the taurus cooling fan.  There is no more room under the hood....a big change from the 2.3T that was there.
Ill post some pictures tomorrow....
Travis
Reply #145
Good work so far. It is a slow grind down the stretch, seems like something is always popping up. Looking forward to more progress pics!
Reply #146
Always liked the 351 turbo setup.  I was going to do that a long time ago.  I have a 460 in a 85 T bird that is built for boost and 2 91mm's sitting and waiting.
But all good things come in time.  Best of luck with your ride.
Reply #147
Update...All the wiring is done including the fuel injector harness I made.  I have 2 wires to run for the alternator...thats it.  Wow
I shooting for next saturday start.
Travis
Reply #148
yea
Reply #149
Quote from: turbotrav;423826
Travis
Great to hear Travis!
