Topic: 86 T-Bird 3.8L V6 (Read 1290 times) previous topic - next topic
86 T-Bird 3.8L V6
Do you need to remove the oil pan to remove the timing cover on an 86 3.8L V6?
I know I saw this discussed on here before but I can't seem to find it.
The camshaft lobe for #2 cylinder intake valve is wiped. It is strange as I bought
this car and drove it for two days and it developed a miss which turned out to be
the wiped intake lobe. This car has 69K original miles and the engine is clean inside.
I have owned two other cars with 3.8L V6 in them and they both had 200K plus miles
on them when I got ride of them. I was never inside either engine except to replace
intake gaskets. Has anybody else experienced a wiped cam in a 3.8? Thanks.
86 T-Bird V6 C5
91 F-150 5.0L 5spd
93 Mustang LX 351C C4
2013 Honda CRV AWD
86 T-Bird 3.8L V6
On the "84" you definitely need to remove the oil pan first -- believe this is also true for the "86".
86 T-Bird 3.8L V6
Ok, thanks dw85745. Many years ago I had the timing cover off of a 3.8 but I can't remember what year it was. I know I didn't take the oil pan off though.
86 T-Bird V6 C5
91 F-150 5.0L 5spd
2013 Honda CRV AWD
86 T-Bird 3.8L V6
No, you do not need to remove the pan on the '86 3.8L.  I know, I've done it twice because of TC/Block coolant leaks.  But you DO have to remove the crank pulley.  There are some bolts that go through the pan into the cover, though, and those have to be removed.  When you put the T/C back on, there is a corner where it makes up to the block and the pan on either side of the crank that has to be sealed with RTV.  There is absolutely NO reason to remove the pan to remove the timing cover, though.
:birdsmily:
86 T-Bird 3.8L V6
Thanks Old_Paint. I disassembled it a couple days ago and found out you don't really need to pull the pan. The timing cover on this one was starting to leak too as they eventually do. I am now waiting on my cam to show up so I can reassemble it. Then maybe I can enjoy driving it.
86 T-Bird V6 C5
91 F-150 5.0L 5spd
2013 Honda CRV AWD
