Topic: 4 eye projector lights (Read 3494 times) previous topic - next topic
I know this topic has been discussed before, but I have come across a source that manufactures 4 x 6 projector lights. Not the cheap Chinese imitations you can get on e-bay that actually make things worse, but actual projector lights. The metal retaining buckets will need to be seriously modified as the light is completely square. The light itself is capable of both high and low beam, and uses LEDs as the light source. I have contacted the company to see where they are able to be purchased, how much they retail for, and what type of connection it uses. I am thinking it is an H4 connector since that seems to be what most of their other lights use. This company also makes a lot of aftermarket lights for Harley Davidson motorcycles, and are located in the US. When I found out more I will gladly post an update.
Received a reply from the manufacturer. They confirmed they are in fact an H4 style connector, and gave me a "local" (as in in another state) source from which to purchase them. Due to the holidays, I haven't had time to call and ask about the price.
please post more info when you get in touch with someone who sells them.. i want to put HID's in the new TC before it hits the road
I'm also watching for updates :D
The mustang needs good projectors.
I have had some troubles logging in to the site. Haven't heard back from the seller yet, but I placed another call to them today. The company that manufactures them is JW Speaker. The specs are as follows:
Product Specifications:
Light Source: Light Emitting Diodes (LEDs)
Output: Raw: 1,300 Lumens; Effective: 750 Lumens (Low)
Raw: 1,300 Lumens; Effective: 850 Lumens (High)
Input Voltage: 12-24V DC
Current Draw: 3.6 Amps @ 12V; 1.5 Amps @ 24V (Low Beam)
3.6 Amps @ 12V; 1.5 Amps @ 24V (High Beam)
Lens: Tempered Glass
Housing: Die-Cast Aluminum
Standards & Compliance:
DOT Approved - FMVSS 108 (On-Road Illumination)
Transport Canada Approved - CMVSS 108 (On-Road Illumination)
ECE Reg. 112 (Headlamps)
Buy America Compliant
Sealed to IP67
I have located a source online that sells them, but they are showing the low beams, and the high beams. Not the combination high/low. They have them listed at $390 a piece. Here is a pic of them.
390 a piece? screw that! they're not that great looking, either.. oh well.. the search continues
Darren, how do you like the light output??
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
It's indescribably bright with the hi-beams on and the low beams are just as impressive compared to the stock glass sealed beams. I am really big on lighting and always ran the halogen high output sealed beams. Its kind of like comparing an old lantern to a flashlight IMO.
Darren
http://www.ebay.com/itm/165mm-H4656-H4-EURO-CONVERSION-HEADLIGHTS-/330678825361?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item4cfdfe7191 These are also a Good quality replacement. I have these in the 86 mustang, and still look and work good. They are also a drop in replacement, no modding of the buckets required :D. H4 bulbs to have a different pin configuration of the original sealed beam though.
Beam pattern:
Definitely not as costly and look basically the same.  Not really sure what the difference would be to tell you the truth and if you do not have to mod the bucket that is a plus.  They use the same bulb as the ones I used so that seems pretty consistent which is another plus.  I saw some really cheap ones on Ebay when I was looking and that just scared me away as I don't need something failing on me like lights or brakes!  Good find bullitt4514!!
Darren
Quote from: Aerocoupe;380094
What about a diamond style stock replacement?  I have these in my '83 and really like them.  Here is the thread on the install:
http://www.foxtbirdcougarforums.com/showthread.php?31691-New-Diamond-Head-Lights-for-the-83
Darren
MUCH better.. what'd they cost you and where did you get them?
In the thread you quoted the vendor's website is given on post #6 (http://www.racinglab.com/redicutsebeh.html) and I believe they were around $100 for all four plus shipping.
Darren
that's a hell of a lot better, for a hell of a lot better looking lenses lol.. i just saw pictures and came right back here and started typing my reply.. i didn't even think to look for a link.. i'm a moron :) lmao
