Topic: Replaced the speakers, using stock HU and AMP (Read 3872 times) previous topic - next topic
Turned out to sound  good! :D
I have a whole $50 in the speakers :headbang:
Did you run all new  wiring?
Mike
Nope. Just replaced the speakers. everything still ran by Original amp and head unit.
Turned out to work better then I expected it to.
I put some new Kenwoods in the doors, I need to do the front and rears also.
Mike
What sizes did you use in the dash, door, and rear deck?
Quote from: bullitt4514;375888
Quote from: bullitt4514;375913
Dude, that is bad ass.  Did you have to drill ANY holes or cut ANY metal or was it all plug-and-play?  Do the door speakers protrude into the door panel grille or into the window track area?
The speakers I used fit like stock. On the door panels the mounting holes did not line up with the oe speakers, but a drill fixes that easy enough.
I have those pyles in my Pontiac  and I was suprised by how good they sound  .
