Topic: Winter stuff to do (Read 8264 times) previous topic - next topic
Winter stuff to do
I wont be changing for a long time Ive still got another new mechanical advance in the box I'm stuck with.
Winter stuff to do
The Big brown truck stoped by :)
Winter stuff to do
Got started on making a home for those new 31 spline axles. If I have time after work tomorrow I will be dropping it off at a local rear end builder who will be sand blasting it and welding the tubes to the center. While there  he will install the new track lock and some other tings.
Winter stuff to do
That looks pretty sweet.
Only car related thing done today was to install a trickle charger on the XR7 optima uber battery!!  :)
Travis
Winter stuff to do
What dist. are you running. I had a MSD Probillet in my ranger, I loved it. Mine had different bushings you could change to raise or lower full advance timing and it had different springs you could change for how fast or slow the advance came in. Really good Dist., if I swap from EFI to carb I'll be using a MSD Probillet.
Winter stuff to do
is that a bumper jack i see? i want a couple of those so bad!!
Winter stuff to do
Quote from: Bruce M;377257
That's what I'm running I have two of them the first one the shop that put the steel gear on didn't set the end play rite and It hurt it self on start up had a different Machinist fix it and While I waited I got another one. Its a great distributor I have 1 light spring and one heavy spring and advance is in by 3000 rpm I gonna play a little more when i get the carb jetted down a little to get a little bit more around town 4th gear low rpm drivability
Winter stuff to do
Quote from: Shadow;377265
Why yes it is. I picked it up the other day for $175, Ive wanted one for a long time. I love using my buddies when I work at his shop.
Another friend stopped by and told me a funny story He says he knows why there called  bumper jacks and not side of the car jacks. He was picking up his old datsun pick up from the frame at the rocker and almost rolled it if he didn't leave the passenger door ajar when the truck was  going over it swung open and stopped the truck from going over.
Winter stuff to do
sounds like a pretty good deal.. i usually see them upwards around $300 and they disappear just as quickly as the ads are posted.. and yeah, i would only advise using it on the side of a vehicle if you have 2 lol
Winter stuff to do
Pull graph looks good westie. Car sounds fantastic, too. If you can get that leaned out a hair it'll be perfect. Better to sneak up on it from the rich side, I say.  Best power around 12 to 12.5 in my experience. Any richer than 12 can lose quite a bit. I'd bet there's 20-30 more ponies right there.
 Oh, and distributor???? :poke:  What's a distributor, again??  :poke: :rollin:
Winter stuff to do
Quote from: flylear45;377314
Says the one guy on this site without a dizzy!!!  :)
Travis
Winter stuff to do
Quote from: Shadow;377269
They have another one for the same price I almost grabbed it.
Winter stuff to do
Gotta put this away before it gets covered in rain. I'm trying not to mention the S word Shadow doesn't like it. So no work on the car till my cs are done  cs. Should be able to get 8.8 dropped off in a day or two.
Winter stuff to do
i don't know anyone who DOES like the s word.. lol
Winter stuff to do
That yellow hunk of iron in the pic with the 8.8 on the bumper jack makes me and my wallet like the S word It netted me a TKO + last year. But I don't like it as much as I did when I was younger in fact I'm not a big fan of the cold anymore either :)
