Topic: Alignment Specs (Read 1632 times) previous topic - next topic
Alignment Specs
Does anybody recommend a good alignment spec for the t-bird? I have maximum motorsports camber/caster plates with OEM shocks and struts -- nothing modified and the car is not lowered. I installed the cc plates for street use, not the race set up. I'd like to go a bit more aggressive than the factor street set up but not so aggressive a ruin my newer tires in the first 1,000 miles. The wheels I have are the 15" mustang finned wheels from the '87 - '89 mustang gt. The specs with the mm instructions are as follows:
Street Use
Caster = 4.5 degrees positive, Camber = 0.5 degrees negative, Toe = 0.5 degree toe-in
Race Use
Caster = 6.0 degrees positive, Camber = between 1.5 degrees negative and 2.5 degrees negative, Toe = 0.5 degree toe-out
My Initial Thought
Caster = 5.0 - 5.5 degrees positive, Camber = 1.0 degrees negative, Toe 0.5 - 0.00 toe-in
Has anybody done a similar set up to this? Does anybody have any advice or suggestions?
Alignment Specs
Caster = as much as you can get
Camber -0.75 to -1 deg
Toe in 1/16"
Caster will not wear tires, get all you can because it will help with dynamic camber change. Adding the toe in will help tracking and also help compensate for the static neg camber numbers. You dont want zero toe with squishy stock bushings.
Alignment Specs
Why did you putt CC plates on it?
Alignment Specs
Never mind. He lives near Eric.
