Leaking Oil....
Today i took the car for a ride. Like every time when i am at the gas station, i do a fast check of the engine. Where the crankshaft is located , there are a leak. It´s little and very very slow. I took my manual and read
"A leak equivalent to 2 or 3 drops in 30 minutes with the engine running to highway speeds, will be not important,but the equivalent to a little salt can means problems with the seal...."
And well, the leak was 2 little drops, and checked the crankshaft pulley again and is nearly clean......
I only want to know if this is true, or i need to start saving for a expensive reparation.....
Needless to say, when i do my oil change, i add 4 pints without filter , and get back 3.75 six months after....
(EDIT)
mmm, sorry, i was talking about quarts, not pints.....
