Topic: TC Question (Read 2863 times) previous topic - next topic
TC Question
On my Turbo Coupe, there was a small, finned cooler mounted in front of the condenser.  It was about 4 inches, by 10 inches.  Was that an engine oil cooler?
The reason why I'm asking, is because that coolerwas mounted on a mounting bracket that I need.  The bracket I need is on the passenger side and bolts to the core support under the condenser and also bolts at it's other end to the core support above the condenser.  I have the one my TC came with, but need another one to bolt my aftermarket 30,000GVW tranny cooler to.
I threw the stock cooler that was mounted to that bracket in the trash.  If it was still on the car, it would be easy to determine what type of fluid it cooled.  It can't be the power steering cooler.  The power steering cooler is nothing but a tube that's mounted in front of the condenser.
If I knew what type of cooler the bracket I'm looking for holds, I'd be able to locate one of those brackets.  Thanks for any help.
William
TC Question
power steering oil cooler?  the engine oil cooler is between the filter and the block on the 2.3 and has coolant flowing through it.
TC Question
If your TC was an automatic, that was the trans cooler you tossed out.
TC Question
Sounds like the trans cooler to me.
...and there was light!
TC Question
Don't the stock radiators that come in a TC have an integrated tranny cooler?
William
TC Question
Higher performance cars have seprate tranny coolers because they cool better than integrated ones. I would assume radiators would be the same in these birds TC or not. So it could have both integrated and seprate. One or both coolers could be used.
TC Question
Quote from: Chrome;374929
Of course higher performance cars have seperate tranny coolers, but we're talking about an A4LD transmission that the auto TC's come with.  The cooling demands for a stock TC with that transmission shouldn't require an external tranny cooler; especially if the 5.0L Birds don't require one to properly cool the AOD trannies they come with.  That just doesn't make sense to me.
William
TC Question
the 5.0 birds should have had an external cooler, AOD's hate heat more than most transmissions.. but the tc WAS fords tbird performance car, therefore it got an external cooler
TC Question
My 86 XR7 used the radiator cooler and an external as well.
TC Question
Quote from: 88 Blackbird 5.0;374937
The 5.0 birds were not considered performance cars. The TC's were.
TC Question
This is too good to be true!  You have two TC's with tranny coolers?  If you can give me your address and let me know when you leave for work, I'll stop by shortly after you leave and have my choice of which car I want to take the bracket from.  :P
William
TC Question
Quote from: Shadow;374940
That's what's so laughable about Ford putting tranny coolers on TC's, but not Sports.  If you had to choose which trans needs maximum cooling more between an AOD and an A4LD, the AOD would be the correct choice, hands down.  There's a good reason why I'm installiing a 30,000 GVW tranny cooler on the Red-Winged Blackbird.
William
TC Question
That's messed up! lol
