Topic: whats your bird weight??? (Read 2863 times) previous topic - next topic
whats your car weigh? i wanna shed some LBS off my tbird but still keep the interior stock lookin. wanna try a grudge race. any tips??
i'm ashamed to say my blue TC only lost about 200-250 when i ditched the 4 cyl EFI, factory alt wiring, AC junk and some un-needed items (cruise control unit, factory amp, EQ, radio and all the wiring).. i think it gained more than that back with the 413 and turbo setup :( .. she probably weighs about 1-200 over the original weight
The last time I weighed the Sport, it was 3340 lbs.
On the tracks scale 3375 lbs.
Mine weighed 3560 on the track scales, which included 2/3 tank of gas, mini spare, and small tool bag, still has all options and dual power seats... With driver 3760...
mine still has the full interior, fancy trunk carpet, two amps and one 10"sub 3,000lbs without my 225lbs a$$
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
anyone care to tell wut they took out or stripped to get the weight down. i would like my car to be 3,000 lbs
a good start is to se all the sound deadener off the floor boards and trunk floor.. you'll get more road noise inside the car, but it's a good start
these bumpers dropped like 70lbs
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
I weighed my '97 when I first got it. With a full tank of gas it was right at 3,600...
Quote from: 347Thunder;374279
where did you get those from?
he built them himself
And I'm going to THANK 347thunder alot for seeing what he came up with.  My aluminum bumper should be done tomorrow.  My steel bumper with all the triangles cut out of it with the supports and everything was still 28#.  I'm hoping my aluminum one will be less than 10# even with the extra fog light brackets and stuff I put on mine.
I sed 40# of the glued on sound deadener off the floors.  Theres probably another 40 of jute batting on the back of the carpet, but I just left the whole works out.  All thats on the interior of mine is to race buckets and a dash, lol
i'd be interested to hear everything 347thunder has done to lighten his car.. my blue TC is overweight because i wanted to keep all the amenities it came with from the factory, with the exception of the factory stereo, to keep it comfortable and (almost) stock appearing on the interior side of things
Another couple of the big offenders are the  power seats and the power window guts. I wouldn't sacrifice the PW myself. Along with the sound deadening on the floor, you would be surprised how much weight the carpet holds. It was a pain in the balls but i ripped everything (padding and what not) from the underside of the carpet. After steam cleaning and drying i was shocked that the carpet weighed like nothing. Obviously you pick up alot of noise doing that but in a fun street car or a "race car" who cares.
While the 87-88 Fox T-birds are heavier than their Fox mustang counter parts, they are pretty close to the SN95s. Mine (mustang) was 3400-3500 with myself and a friend in it. Both of us are around 170.
~John~
