Topic: looking for a TPS (Read 1894 times) previous topic - next topic
looking for a TPS
I am looking for someone with a known working TPS for the 3.8 for my 88 Cougar. I do not know if it is the exact problem so am looking for a cheaper used one to either rule it out or pinpoint it as the issue.
Thanks
:ford::oldcougar::mercury:
looking for a TPS
I've got one in the garage from my old motor. Been sitting for a while, but it worked fine when I had it. I can get pictures for you hopefully tomorrow.
PS did you run codes? What's the problem?
looking for a TPS
Also when you put the car in park from drive it idles up and down and most times stalls. If you keep it in gear no idle issues once its in park it idles real rough.
looking for a TPS
Bump
looking for a TPS
$10.00?
looking for a TPS
Quote from: vinnietbird;374690
$10.00?
I'll take it if that means you have one... Can you pm me your PayPal again I'll send payment on Thursday.
looking for a TPS
vinnietbird@sbcglobal.net
please send it as a gift, and also give me your mailing info. I'll get it out later today.
looking for a TPS
Payment sent.. Thanks again vin
looking for a TPS
Got it vin.... Thanks a lot. Now I read somewhere on adjusting it after installing. I can't seem to find it how exactly do you adjust it.
looking for a TPS
Glad you got it. Hope it helps. Good luck, friend.
looking for a TPS
Still looking... The TPS I got apparently is not the correct one. I went to replace it and looked totally different.I could not find anything that looked like what I got. Mine looks like the pic below.. Unless I'm an idiot and am just missing it.
looking for a TPS
That is a tps, and a slightly diffrent style, but operates the same. Oldfuelinjection.com has a diagram if you want to cut your wires after the connector and put some different connections to slide on the pins.
You should be running codes instead of throwing money at it. What codes do you get? Oldfuelinjection.com will give you a walkthrough on that as well.
looking for a TPS
I do not get any codes...
looking for a TPS
Not even a pass or stored memory code? Did you try clearing them?
