Topic: Differentiating differences in differentials... (Read 1786 times) previous topic - next topic
The rear end of my '85 is toast. I have an opportunity to pick up a '91 3.8 for cheap, but I need to know if it is a direct swap on the rear ends.
Thanks in advance.
Re: Differentiating differences in differentials...
what car is the 91 out of, If it is out of a t-bird/cougar, it is most likely a waste of money. You can get one off of a mark VII(1 1/2" onger) a mustang(About 1 1/2" shorter) But you will have to mesure your rear axel. In 1985 the rears went from the mustang width, to its own width. So it oculd be either a mustang or later t-bird/cougar rear end. Either way it should fit okay. Here is everything that you will want to know.
http://www.coolcats.net/tech/general/axleinfo.html
The '91 rear end is completely different. 89-97 T-Birds and Cougars had an independent rear end, while your '85 has a "solid" rear.
yeah that is what I ment.
