Topic: need measurements, 83-86 AND 87-88 (Read 3408 times) previous topic - next topic
i need the measurements for 83-86 AND 87-88 upper and lower control arms if anyone has a set off the car or knows the measurements, i'd appreciate it if you could post them up :) .. need center of bolt hole to center of bolt hole.. i haven't got a clue if 4 eyed control arms are any different, so that's why i'm asking for both, if they're the same :p .. i lost the papers with my 87-88 measurements and want to build my uppers and lowers before pulling the stock 1's out either car.. i also want to build a new jig for mass producing these as i build mine, so any light shed on this subject is highly and greatly appreciated :)
Sha
Quote from: TOM Renzo;373217
Wait you want the rear control arm  measurements Now i understand. I have a set of those also. I will measure them for you tonight.
yeah.. sorry for the lack of saying rear, i didn't even notice that i left it out.. thanks tom
They're the same.
I had to dig up my old numbers from however long ago it was when we did them.
Upper: 10-3/8"
Lower: 18-1/8"
Those *should* be right, but Tom can verify with his dimensions as well. The notes I have are from 12 years ago or so.
holy , talk about some old notes lol thanks chuck, i'll wait for tom to verify before i do anything
They were from when I was back @ Kenny Brown and we were building the prototypes for the arms they were making.  The dimensions were taken from some arms off one of my cars.  The dimension on the lowers might be off slightly, but we can verify with Tom's info.
I just
Chuck
Sounds like I would go with 18-1/6"  for the lowers :p
Tom, the only cars that got round bushings in the RLCAs were the EARLY Foxes.  I think even that was only on the Mustangs/Capris and Fairmont/Zephyrs.  Both of my '80 (Big) Box Cougars had oval bushings. The non-108" w/b Cougars from 80-82 (i.e. the non-XR-7's) were on the Fairmont platform, and *may* have had the round bushings in them, but I don't know.  The arms would be the same length center-to-center, regardless of whether the bushings were round or oval.
I de
If you needed an adjustable on one or the other, I would at least use a heim on the uppers, but not the lowers.
that's what i was thinking tom, since you and chuck came up with 2 different measurements for the lowers.. but i wouldn't use a hiem, i'd go with a 'bushed' rod end like so:
http://thorbros.com/4-link-parts/4-link-bushings/adjustable-4-link-bar-end-1-stud
ok, uppers :p
The uppers are the better choice.  If you do the lower, put the rod end on the axle end of the arm.
If you go with fixed lowers, and adjustable uppers, the 1/16-1/8" difference in the lower measurements won't matter.
thanks to you both.. i'll make the uppers adjustable.. if guys want to use them at stock length, they can just shove a long bolt through their stock UCA's and adjust the new 1's accordingly.. and for the record, chuck, i know if i made the lowers adjustable, it would have to be on the axle end.. or else it would throw the coil spring into a bit of a bind ;)
