Topic: Motor mounts..solid rubber or hydraulic? (Read 4336 times) previous topic - next topic
Which mounts do you guys go with, solid rubber or hydraulic?  Any advantages/disadvantages to either?
87 TC (southern car)
88 XR7(Mustang front brake upgrade)
78 F250 Supercab (southern car)
76 Marquis (southern car)
71 XR7
89 Escort GT (southern car)
When I had my TC, I used the Chuck W's  wouldn't use anything else.
I used the solid rubber in my car, I like them. The hydraulic mounts go bad very quit. I had new hydraulic mount in my car and they didnt last two years.
X2 on the Chuck W. mounts, best there are.
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
who makes the chuck W mounts ?
chuck w :giggle: his site is turbochuck.com
I als
That would be me.  The website given above will have all the info needed on the mounts if you're interested.
I want Chuck W mounts but couldnt afford them when I swapped in the HO motor. So I had to settle for the solid rubber, they're ok for the money. Mine were $27 a peice.
The factory mounts are filled with frog jelly to dampen those awful nasty engine vibrations that everyone complains about (not). It leaks out real quick. Use solid rubber. If they don't tell you in the catalog, go for the cheap option, it will be solid. El Cheapo solids beat the cr*p out of OEM.
My last set of hydro mounts split on me while I was putting the motor in my car
87 TC
