Topic: A few parts from the well cared for '87 TC. (Read 2061 times) previous topic - next topic
Well, the TC is pretty much stripped. Still have a little ways to go though. Here's a few more small parts for sale. Everything except spindles are + shipping.
Drivers side taillight. Great shape, about an 8 out of 10 - $50.
Multi-function switch, very good condition - $15.
Auto dimmer rear view mirror - $25.
Door lock actuators, excellent condition - $15 ea.
Power window motors, both sides. Windows roll up/down quickly. No slowing or stalling. $10 ea.
Side mirrors, exc. cond. - $10 ea.
Factory rear speaker covers - $10 pair.
Inner and outer dew wipes. Perfect condition. Soft pliable rubber on outside, soft felt material inside. - $20 per side.
Tired of using that prop rod on the '83-'86 hoods? Slap in these direct replacement, bolt on '87 hinges w/springs. So long prop rod! - $25 pair.
Working A/C compressor unit - $35.
Good spindles - $50 shipped.
Also have the 3.55 rearend with rotors that are within specs - $150.
Lower 1/4 mouldings (behind rear wheels) - $15 ea.
Battery tray (no holddown) - $10.
Working power antennea - $15.
2 factory fog lamps (1 has a broken lens) - $20 pair.
Flywheel shield (metal piece that goes between bellhousing and block) - $10.
Armrest marker lights (several) - $8 ea.
That's it for now.......more to come!
do you have the inner most lights for the turbo coupe girlle
What about the rear control arms....upper and lower?
1988 T-Bird Sport Coupe--5.0 HO, MAF swap, 1-5/8" shorties, BBK/Flowmaster exhaust, Explorer intake, 70mm Edelbrock TB, T5, B&M short throw, Centerforce clutch and PP, disc brake TC rear w/ 3.55's, TC front brakes, '98 Cobra springs, DIY SFC's, other misc .  14.05 @ 98mph with launching too low and shifting too high.
PM's sent out.
I would like the power antenna if its still available
PM sent.
Rear coil springs?
PM sent.
PM box cleaned out!
Is the a/c compressor still available?  Do you know if it was converted to R134a, or if it's always run R12?
'87 Cougar LS V6 (stock) Daily Driver
'06 Lincoln LS V8
'12 F-150 SCrew FX4 5.0L
'80 Thunderbird V8 (mild 304) [sold to friend]
Quote from: bike70ride;374263
I still have it and I have no idea if it's been converted to R134 or not.  What's required to convert it?  I thought it was just a different refrigerent mixture?
I don't think anything is required, I was just wondering if it had been changed over since the oils don't mix and I would assume it'd need a thorough cleaning to re-use.  But, probably that'd be part of nay new install anyway...
'06 Lincoln LS V8
I have the v-belt pulley set-up, so not sure I can use the serpentine...
'06 Lincoln LS V8
I'm pretty sure the pulleys interchange.
PM sent
