Topic: k member question (Read 2457 times) previous topic - next topic
k member question
HI, i am new to the site i own an 88 thunderbird(will post pics when i get some) but anways i was told tubular k mebers for fox bodys wont work in these cars:( is this true? over the winter i plan on puttin one in an puttin a BBF or SBF on nitrous to run a local X275 class(drag car only). i appreciate any tips or info given thanks alot
k member question
welcome! and your source is wrong, a mustang k member does fit a fox bird.. i have a QA1 k member in 1 of my birds, with mustang tubular a-arms
k member question
thanks alot, i was lookin at a Team Z k member or racecraft
k member question
i looked at racecraft as well.. nice stuff, but i came across my QA1 on a local forum, NIB for half the price.. i know 2 or 3 people that have used racecraft's parts and they speak highly of them
k member question
Yes, they'll work, but they're not an 100% direct bolt in.
There's a 3/8"-5/8" difference in the frame height mountings between the Mustangs and Tbirds (with the TBirds being taller) that will require some spacers.
A search of "K-member" will yield several threads on the subject.
k member question
Any welding shop should have some 3/8" flat stock laying around. I got mine for free.
1979 Ford Fairmont
[/B]
k member question
a drill bit and 2 pieces of 3/8 plate will do the job
k member question
you can go this route http://www.lethalperformance.com/suspension-k-members-k-member-spacers-upr-products-c-13_339_6153_9817_9819/upr-79-04-mustang-3-16-k-member-spacer-kit-p-33828 but I just pulled it into the frame with my impact, same thing on the mustangs i've done.
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
