Topic: 84 cougar carb swap (Read 2579 times) previous topic - next topic
84 cougar carb swap
i just pulled my stock "efi" 302 out and im dropping in my built 306. i have a few questions about the tranny kickdown rod, ingnition, fuel pump.
whats the best way to mount the TV rod to the carb? i have a high rise intake with a 750 holley.
ignition i was reading a few fourms and they said my ingnition system wouldnt work? i all ready have a new dizzy *vaccum advanced* but wondering why i couldnt just hook that up.
the 84 cougar has 2 fuel pumps a high flow in the tank and an inline pusher pump *low pressure* wondering if it had enough pressure to run a 750, also wondering how to run a line into the tank or could i just leave it in there? would it still pull fuel if i left it in there?
84 cougar carb swap
You have the fuel pumps backwards.  The in-tank is the low-pressure lift pump that feeds the high-pressure in-line pump.
Without a regulator, you can't use the EFI pumps for a carb application.  They're running about 35-40psi vs the 5-7psi that's normal for a carbed car.
84 cougar carb swap
Yes, i was thinking i would have to get one, Also im pretty sure the low pressure is in the line lol but ill do some checking lol
84 cougar carb swap
Low pressure is in the tank. I doesnt make much since to boost the pressure if the tank pump is already high pressure does it?
The low pressure is in the tank and the in-line pump is the high pressure pump. I've heard of people using the low pressure in the tank with carbs, but you'd need a pressure regulator.
84 cougar carb swap
Quote from: 4eyed'Cougar;371512
No...low pressure is in the tank...I wasn't guessing.
84 cougar carb swap
I've done this swap on my 84 using the pumps with a mallory  4309 regulator and a dura spark ign. I have a very descriptive  post how I did it....I just have to find which forum I posted it on and I will post a link.
84 cougar carb swap
.....here's one but it's not the more descriptive one....I'll keep looking.
http://www.fordmuscleforums.com/all-ford-techboard/464848-fuel-system-help.html
EDIT.....can't see for looking  DUH!
http://www.foxtbirdcougarforums.com/showthread.php?31828-duel-fuel-pumps-to-single-high-pressure
84 cougar carb swap
.......found another one, hope it helps. Keep us posted on your progress as I may have forgotten something else along the way.    http://sbftech.com/index.php/topic,15112.msg146399.html#msg146399
