Topic: new ign switch (Read 2878 times) previous topic - next topic
Re: new ign switch
haha I was thinking about just hammering away... I dont have a steady of enough hand to slightly drill out that small nub.
Re: new ign switch
I bought a set of the tamper torx at the auto parts stoore.. approx $8... Have used a small pair of vice grips to loosen them in a pinch...
Re: new ign switch
Quote from: TurboCoupe50
ditto on the buying a set of  tamper torx bits. come in handy, expecialy when you dive into a tv or something companies dont want you messing with.
Re: new ign switch
I'm thinking that's whats wrong with my '85.  I'd crank it over, and it would run as long as the key was turned sort of halfway between start and run. Let go of the key and it shuts off.  I think for the peace of mind I might replace the ignition switch and lock cylinder all at once.
Re: new ign switch
I just got done bout 5 minutes ago replacing my ignition switch. I uhh, rigged, it. I used a t-15 i believe and tapped down the tamper pins alittle bit, then used the t-27 and pounded it in. Worked good. Saved me 10 bucks by using what I had. Couple pinched fingers but Its worth it. \
I had to remove the dash cluster trim to have enough space to mess with the rear screw on the switch. So that added like 5 minutes. All in all took bout 30 minutes
Well 1 of the 2 draws was fixed.
The ignition switch was one of the problems.
Now onto finding the draw in Fuse 8.
Re: new ign switch
What circuit is on fuse #8?
