Topic: Need help FAST !!!!! FIXED !!!! (Read 36813 times) previous topic - next topic
Reply #300
See what I mean, I have no ideas what you meant. What positive socket wires? From the inner light? I'm running in and out from here to the %$@*&%@ car.
Reply #301
Vin
Reply #302
I think I have the wiring mostly done. Now for the inner lights. There are three wires...two black and one white. The wires from the harness (2 of them) are black, and brown.
Now, with the three wires from the inner light....Do I connect the white wire from the socket to the brown wire in the harness, and then one black wire to the harness black wire?
Reply #303
Quote from: TOM Renzo;372728
Vinnie the 1157 lamp has a double filament. Dims and brake/signal. One filament is brighter than the other just use one of those wires. It is just for testing purposes. If the lamp is duller then use the other wire. Just leave one hanging in the BREEZE!! Normally the red wire is the signal/brake and the black is the dims or parking lights.
I don't have those color options. I have a brown wire and a black wire from the harness, and two black wires and a white wire from the socket.
Reply #304
the inner socket's positive wires.. 1 is the 'parking lamp,' the other is for turn signal/brake light.. you can bridge the signal/brake light wire to the center socket's signal/brake light wire and all 3 lights will still light up when you use your turn signal or when you hit the brakes
Reply #305
Just omit the green wire from your red/green/black/white combo. The green wire feeds the innermost light, so omitting it will make that light revert to park only.
Reply #306
SO, do you mean put the two black wires from the socket end to the black wire in the harness, then the white wire from the socket to the brown wire in the harness?
Awaiting confirmation..........
Reply #307
Quote from: Thunder Chicken;372733
I'm removing the sequencer from the car altogether. A fellow member has a kit like mine that I'm going to get and re-install once this is past me. I'm going back to stock right now. I have another trunk harness I'll graft in before the sequencer kit I'm getting goes in.
Reply #308
holy  i just got lost LOL.. do either of the black wires on the socket have a stripe?
Reply #309
Quote from: Shadow;372732
I re-read that. Which wire from the center would be the right one to tap in to?
Reply #310
Quote from: Shadow;372736
No.
Reply #311
that someone else would have to lead you on.. i'm not sure as i don't have a diagram in my face or a car (here) to test to figure it out..
Reply #312
I'm telling you....You seem to understand electrical better than me (so does any first grader), imagine my point of view here.LOL.
Reply #313
Thunder Chicken may know, he designed the system.
Reply #314
Quote from: vinnietbird;372738
No.
well that's stupid.. must be a chinese socket.. lol
