Topic: Need help FAST !!!!! FIXED !!!! (Read 36844 times) previous topic - next topic
Reply #285
including the ground(s)? i bet if you clipped the ground wires to the outter sockets, added a stretch of wire and grounded them on the inner-socket's ground, they'll all work
Reply #286
Thunder Chicken stated to take the red, green, black, and white wire to the passenger side and twist them together. That's what I did. I got the wires from the yellow harness of wires from the sequencer as directed. Not the center ground wire, or the driver side. maybe I missed something, but I don't think so.
Reply #287
:dunno:
Reply #288
Quote from: Shadow;372708
:dunno:
Yeah, Me too.
Reply #289
my best guess is the ground, since the inners are working and they're on their own ground.. did you twist the wires all together or did you twist the wires on the IN side of the sequencer with the socket side of the harness, color to color, individually?
Reply #290
Sequencer side.....Oh, wait a minute. Maybe that was wrong and I mis-read.
Reply #291
Now what? Man, I HATE this stuff. More than I can say. I gotta get fundage to get that other sequencer kit stat.
Reply #292
yeah lol.. twist them together, color to color individually, basically making it a stock harness again
Reply #293
Quote from: vinnietbird;372712
I guess looking back, twisting the light ends make s more sense. THIS is why I DON"T do electric. Some things I just get. Some things I don't. This is one of those things that eludes my simple little mind.
Reply #294
I'm going back out to look...................
Reply #295
it's ok electrical noob lol.. check your fuses just incase you popped 1 by tying them all together.. with the wires hooked up as 'factory,' everything should work correctly
Reply #296
I THINK I can put it back to stock, but one problem. The sequencer kit came with new inner bulbs. They have three wires, and the factory bulbs had two. What do I do with the inner 3 wire lights that took the place of the two wire sockets?
Reply #297
The fuses look good.
Reply #298
The 3 wire inner lights are holding me back right now from "repairing" the harness to stock.
Reply #299
for now, you can leave 1 of the positive socket wires disconnected for testing. it won't be hot because it's coming out of the socket and not the harness.. you can't really mess it up.. if you have to wire it temporarily to drive it until you get another sequencer, you can tie the turn signal/brake light wire in with the center bulb's signal/brake wire.. but for now, lets focus on getting your outters to work properly! lol
