Topic: Need help FAST !!!!! FIXED !!!! (Read 32880 times) previous topic - next topic
On the left side by kick panel fuse area there is a ground that I think is for fuse or headlight switch not sure which.
And guessing but by glove box isn't there a blue relay for blinkers?
Quote from: vinnietbird;370992
Re-ground it? meaning, tap into the current ground, and ground the light twice?
Cougar I didn't see this before I posted my .02, but that is exactly what I meant.
Thats a back feed in
ould assume.
If you pinched a positive wire, say around the colum, it might not be enough to blow a fuse, but it might be enough to give you the effect of a bad ground. I would test around your colum and dash with a test light or multi meter, for voltage.
I'm thinking it's in the dash area. I'm going to pull the dash panels and gauge cluster (super easy stuff), then start looking for every wire I can possibly see. If I have to, I'll yank the "bleepin'" dash Friday morning and do it that way.
I really appreciate you guys, and thanks Tom for the list. I'll be using it.
Vinnie, did you say you pulled a seat when you did the heater core?  Maybe one of those grounds under the seat got pinched/knocked loose.
I agree with all Tom has said on this one. I am thinking a connector or something got jarred loose when you did the dash. When stuff messes up after I do work I concentrate on that area first.
I had a single connection bad in a 4 wire connector that gave me fits on mine. It may be something like that here.
Keep at it and you'll get it.
Yeah, as soon as I have time, either Thursday after work, or Friday morning, I'm yanking it all from the front of the dash for easier access to what I can reach. I'll get a flash light and look for everything and anything, and See what I can see. man, i hope it's simple. I'm sure it is.....or not.
Reply #39
Quote from: hwy73;371085
I'll double check, but I doubt it's there. Nothing is out of the realm of possibility though. I just have a gut feeling it's within the regions of the dash.
Reply #40
Vinnie, all indications are of a ground issue. The dash is the best place to look for problems because you just worked there. Low voltage can cause modules to freak. I don't know electrical system of these birds well yet, but I don't know of any modules in the tail light system other than your seqential. If all else fails, check voltage there. Module could be bad also. Re-grounding the sockets is an exellent idea for diagnostic purposes. I can't wait to see the results of this test. All other responses to your delema are much better than what I had to say. This advice is for if you are just grasping for straws.
Reply #41
All responses are great. I will keep listening to every idea out there, and I'll make sure to post what I find when I find it (not IF, but "when").
Reply #42
Dropping the column as my first plan of attack either this evening, or after work tomorrow. After that....well, we'll see what happens.
Reply #43
Vinnie, there's a ground over by the ECM that I'll bet you forgot to reconnect.  For the car to die like it did, something more important than the ground for a light circuit has to be faulty.  Pull your passenger side kick panel and have a look.
William
Reply #44
The stalling problem seems to be gone. I had a yellow wire loose under the column. I will check at the kick panel though. I'm HOPING that one more wire under the column is loose or something. I'd like this to be a small issue, and simple to find.
