Topic: 87 turbo coupe fuel tank/stall problem? (Read 1349 times) previous topic - next topic
ok im new here and to the 2.3t seen.i've owned a few 5.0s but now have a 87 turbo coupe all original drives great.except one little thing.well not to sound young and dumb but when i pitch it sideways it tends to die and will not start for about five minutes or more.then fires up idles a little ruff goes back to normal.any info or experiance will be greatly appreciated.thanks in advanced.
no ones had this problem?
no ones had this problem.i have another tank.255lph pump.only difference is my old ones metal on the inside new ones plastic.couldn't see anything wrng with old tank.nothing loose.any help will be appreciated.thanks
How much gas is in the tank when this happens?
anywhere from a quater to half tank.havn't put a full tank in it yet.thanks for responding.
Going out on a limb, check your vam, I didn't have mine mounted solidly and the door would spazz out. Your spring may be weak in it or something
Again just crazy guess, but something easy to check.
You
