Topic: 85-88 non auto climate control ac/heater control (Read 1834 times) previous topic - next topic
got a problem? hook up a heater/ac control in the dash.put back every wire harness the right way,hook up blend cable.heat ,defroster,floor,and mix for defroster and floor all work correctly. ac and vent settings blow out of top defroster vents.help am i missing something or switched something.
Sou
cant find any vacuum leak.help any body, which line controls  ac and vent.blows only out defroster ,floor or on mix setting  any vacuum diagrams would be a help.
I c
Here is the vacuum diagram. With all doors in the NV(No Vacuum) position, the air goes to defrost. As Tom stated.
You never said why you are installing the manual A/C and temp controls.
If you are converting from EATC (Electronic Automatic Temperature Control) to manual, the EATC did not use vacuum to operate the doors.
Softtouch,
You wouldn't happen to have a diagram for the Auto Climate system for a 84 would you????????????????????????
1984 T-Bird Elan 5.0 (sold)
1994 T-Bird LX 4.6
2009 Dodge Charger Daytona 341/400
2013 Camaro SS
Quote from: Smkn600ctd;374523
Softtouch,
From the 84 EVTM
