Topic: Fuel tank issues (Read 14559 times) previous topic - next topic
Fuel tank issues
who said anything about painting the ring with por 15? certainly wasn't me.. the ring should definitely be replaced if it's rusted that bad, because we all know it's going to wind up getting wrecked when it gets beat on to remove it..
ANYWAY.. If a new tank is that cheap, just replace it. just make sure you spray the new tank with a couple good coats of decent paint.. decent meaning no 98 cent cans of walmarts cheap paint lol
Fuel tank issues
I s
Fuel tank issues
Well, I've been pounding on it for a couple days now, and I'm not sure I'm going to get it off without destroying the tank or blowing something up. I'll give it until the end of the weekend. If I can't get the ring to budge at all, I'll call this tank quits. I'll try PB Blaster today.
Definitely need a new sending unit, though. It's still working, but it's in too poor of shape to keep. I did tons of searching and came up with nothing. Making my own is starting to sound like a good idea. At least then I'd know it wouldn't rust away. Either that or salvage what I can of the current unit.
Good news is I found a tank for under 100 including shipping =D
Our world is not merely black and white, nor is it just shades of gray. Taste the rainbow.
Fuel tank issues
pb blast always does the trick for me.. i haven't used wd40 since i was 14, over 10 years ago lol i would soak the ring good enough that there's a little puddle all the way around the ring.. that'll give it more to soak in as it sits.. also try moving around the 3 spots where you can get your chisel or whatever you're using.. that always helps in breaking it loose.. 3 impact points are better than 1 lol.. and cover the filler neck hole with duct tape to keep some of the fumes from escaping and making 1 giant firework.. lol
Fuel tank issues
Haynes Manual directions for removing a tank ring.
 QUOTE Tap the lock ring tabs  with a brass punch and hammer.
Fuel tank issues
suppose you could try a piece of hardwood too,if you don't have a brass punch
Fuel tank issues
Their is also a way to evacuate all the fumes from a gas tank. A good friend of mine owns a radiator shop and told me how to do it many years ago. All you need is a shop vac. One that is certified flame proof. Hook the hose to the exhaust port of the Vac. Then remove the rollover valve and or the sender pump assembly. And then start the vacuum with the hose connected to the fill pipe. The air blowing into the tank will blow out all the fumes. It takes a couple of hours but it works. We do this when installing fittings or return lines for EFI conversions.  Or bottom feed fittings. This allows you to braze or solder on an old tank.  Dont rush the evacuation and test it for fumes before doing modifications to a tank. Hope this helps.
Note make absolutely certain all the fumes are evacuated before putting a flame to a tank. Thanks
Fuel tank issues
Thanks. I always considered a screw driver to be lethal. Now I have proof.
Fuel tank issues
screw drivers are more lethal without a gas tank.. i've heard of plenty of murderers who used a flathead as their weapon of choice lol
Fuel tank issues
Reply #39
Never
Fuel tank issues
Reply #40
Mr tom, I would like to appologize for the way I reacted. You are right that you should go with the safest way possible, even with little chances.
I have been going through some personal things, and I took what you were saying the wrong way.
Fuel tank issues
Reply #41
So, I got busy for a week or so, but now I'm back at it. I've got a lot of good news, a little bad news, and hopefully my final question.
First off, I got myself some real penetrating oil. In my arsenal, I now have PB Blaster, Kano, and CRC Freeze Off. I could tell the difference right away.
Anyways, I sprayed that on last night, and today worked out almost as good as I'd hoped. I got the lines off first and pulled the tank out. The gas that was remaining in it is in the bucket to the right. A lot more than I thought would be left.
http://img90.imageshack.us/img90/7309/img20111023150254.jpg
Unfortunately, part of the piping from the pump broke off along with the line.
http://img233.imageshack.us/img233/479/img20111023145533.jpg
http://img69.imageshack.us/img69/7426/img20111023154317.jpg
Well, anyways, I got the tank out and started working on that sending unit. Cleaned it off to find that the metal had rusted through.
http://img805.imageshack.us/img805/9009/img20111023145526.jpg
Now, I knew I couldn't cut it off, but I had the bright idea of pulling it off. I grabbed my trusty pair of pliers and yanked on it for a while. Probably not the safest way, but it worked.
http://img534.imageshack.us/img534/2997/img20111023151124.jpg
http://img41.imageshack.us/img41/1031/img20111023154234.jpg
It came out better than I could've ever hoped. All I have to do is tear off the rest of the top and remake it. Connector and everything is still in one piece.
Now, onto my question. How do I replace those ends on the fuel lines? I'm assuming it's not just plug and play.
I also still have to remake the electrical connectors, but that shouldn't be that bad. Worst case scenario I machine a block of plastic to fit and find a way to secure it. Best case I make a mold and melt some plastic into it.
As an added question, how is galvanized steel when it comes to rusting? I'm assuming pretty good, but I'm basing that on the chemical structure, not real world experience. I ask because that's what my new tank is made of.
Fuel tank issues
Reply #42
you can replace the fuel line ends... they have barbed connectors on them that push into the lines.... I had to use a special tool though. (borrowed from my mechanic friend)
maybe you cam borrow one from a shop, or rent one from a parts place
Edit:
This was the tool I used for the fuel lines
Fuel tank issues
Reply #43
[url]https
Fuel tank issues
Reply #44
[qu
