Topic: Fuel tank issues (Read 14583 times) previous topic - next topic
Fuel tank issues
I don't know about that tank... it's pretty rusted
Fuel tank issues
Once th
Fuel tank issues
Quote from: daminc;369986
good possibility it is shot.. it's an ohio car after all.. he's in 1 of the worst parts of the rust belt..
Fuel tank issues
they also have replacement connector ends for the nylon lines.... I redid a couple connectors on mine that were mangled. but you need the compression tool.
Fuel tank issues
Quote from: Shadow;369977
at the tank? you sure? after popping the plastic clips off mine, they both slid right off with little to no effort.. and that's on all the fox cars i've owned
hmmm  lol I thought there was one at the tank but I must be wrong.  guess I was thinking about the one on the other end of the plastic lines
Fuel tank issues
Not for nothing !!! But STEVIE WONDER CAN SEE THAT TANK AND SENDER IS SHOT!!!!
Fuel tank issues
they have a special word for people who make comments like that.. for your info, i was on my  phone.. which makes the pictures 25x SMALLER
Fuel tank issues
[quo
Fuel tank issues
Relax, Tom. You've made your point.
To the original poster: you may try using some penetrating oil (PB Blaster) instead of WD-40, which really isn't the best tool for penetrating rusty, frozen parts.
Fuel tank issues
Just a
Fuel tank issues
I don't think that locking ring is going to come off in one piece anyway..
Fuel tank issues
For those of us that might do one or two fuel pumps in our lives, and how easy it is to replace the ring, I'll be able to sleep tonight knowing somone used a screw driver instead of a punch.
I think everyone who has used a screw driver with a hammer knows your not suposed to hit it with said hammer. But a screw driver is cheap, and easy to replace, and something I can pick up 24 hours without any problems. A brass punch or special tool to remove it on the other hand...
And just for the record, I am all over using the right tool for the job, but I won't go broke if it doesn't save me any time, or money, or if I might use it once.
Fuel tank issues
we were trying to relate by sharing the obvious right?
Fuel tank issues
And
Fuel tank issues
I stand by my comment. Its hard to get a spark inside of a gas tank that is still sealed shut. I hope the metal ring a gas tank don't spark while using the brass puncch. I see that as just as likely.
