Topic: Shifter won't go into park? (Read 1584 times) previous topic - next topic
Okay, so I did the heater core today on my '85 T-Bird with AOD and I dropped the steering column a little to give the dash a little more room to move out, probably didn't help any but it made it easier in the '92 T-Bird last year :punchballs:
Anyhow, now that everything is all back together I can't seem to figure out why I can't get the shifter to go up to park. I am going to keep looking at it and see what I can figure out, but hoping someone here might have a simple answer for this issue as I have been trying to figure it out for an hour with no luck.
1985 T'Bird 5.0
1987 Cougar 3.8
1992 T'bird Sport 5.0 HO
Okay, my little brother stopped by and showed me what I did. Apparently the steering column turned while it was loose, works like a champ now. Knew it had to be something stupid simple.
1985 T'Bird 5.0
1987 Cougar 3.8
Thanks for the tip. Gotta try this. Shifter hasn't been normal since. I used a hose clamp on the indicator (which was broken) so the only thing I thought left to check was the linkage.
