Topic: Interior trim (Read 783 times) previous topic - next topic
Interior trim
Well, my 4r70w swap ended up requiring me to switch to floor shift, so i need some full length console goodies. Luckily, my local salvage yard had a TC with a full length console in the right color. Some stuff was already missing though.
I need:
Brushed aluminum style radio/eq/system sentry bezel.
Blank system sentry panel with power port
Console shifter bezel for Either automatic OR manual OR just cubby. Used a 97 mustang shifter, so any will be modified.
Console inside box in good shape. (I had to break bottom screws on junkyard one, had half an inch of 'something' in the bottom)
Let me know.
Thanks,
Chris
87 Thunderbird 5.0
Engine: 97 p-code explorer block, heads, and intake; 88 HO cam, 1.7 RR's, A9P, Kenne Bell 2.1 Flow/Blow 8psi, 42lb injectors, LMAF, 75mm TB, Tuned by Don Lasota
Trans: 02 Stang 4r70w with Baumann TCS
Suspension: Front: 03-04 cobra springs and struts, TC rack. Rear: CHE arms, ChuckW shock mounts, Bullitt springs and shocks
5 bolt with 95 mustang front and mark vii rear.
TC 3.73 L/S rear
03-04 SVT Cobra 17x9's with 275/40r17's.
Interior trim
Hey Cris, Check out my sale ad. I have a tc that I'm parting that I'm sure has everything you need.
