Topic: I need a cutout of a 5 speed shifter hole!!!! (Read 1464 times) previous topic - next topic
Hey guys I need a measurement of the opening, since mine is highly modified due to the B&M shifter, pretty much i need the template of the hole for the stick
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
I cut mine out for the aod, then put the 5spd. in and it worked out. If it helps here's the diagram for the aod, I don't think it needs to be as big of a whole.
http://www.coolcats.net/media/docs/shifter_template.pdf
Problem solved!!!!!
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
