Topic: So what does your fox look like today!!!!! (Read 223070 times) previous topic - next topic
Reply #135
Thanks Stangman.  Yea, V8's do look really good in these cars.  I had some custom solid mounts made up, because my Mac longtube primaries are so close to the k-memeber on the passenger side and the steering shaft on the driver's side.  The collector s are also close enough to the floor pan to warrant concern.  An added benefit of the solid mounts is the fact that the engine is now low enough in the bay to leave 3/4" of clearance between the driver's side hood scoop and the upper A/C compressor bracket.  Now I can install a nice hood liner without worrying about having enough room for it.  Since this car is a toy, I won't mind it if the solid mounts cause more vibrations than stock.  Some guys who run them claim that they didn't experience much in the way of extra vibrations.  I'll just wait and see about that though.
William
Reply #136
I had solids in my 351W Ranger......rattled the exhaust loose weekly!!  But could almost get daylight under the left, front tire when I launched her hard!!  ;)
1988 T-Bird Sport Coupe--5.0 HO, MAF swap, 1-5/8" shorties, BBK/Flowmaster exhaust, Explorer intake, 70mm Edelbrock TB, T5, B&M short throw, Centerforce clutch and PP, disc brake TC rear w/ 3.55's, TC front brakes, '98 Cobra springs, DIY SFC's, other misc .  14.05 @ 98mph with launching too low and shifting too high.
Reply #137
Not mine but it's at my house under my care.
Reply #138
Not mine yet but at my house and under my care.X
Reply #139
very nice^^ love the silver.
Reply #140
Dang Tommy, she's beautiful! You got to get it soon.
Reply #141
I think the reason vinnie is not posting, because he's not done polishing the outside of his bird yet!!!!:giggle::shakeass:
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Reply #142
Thunder, I sent u a pm for that template
Reply #143
Quote from: TommyT;370956
Beautiful turbo coupe!
Reply #144
Quote from: lakenheath24;371063
I did not get it, try again bud
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Reply #145
I sent another one.....is you box full?  Can you send me one?
Reply #146
Still a work in progress
Reply #147
here's what it looks like today.. It's going back together..... AGAIN
started bolting the front end back together
Reply #148
Quote from: lakenheath24;371312
I got it, I will get it out this week
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Reply #149
this is what you'll get, you will have to take your stock one and flip it over and trace out the a/c vents.
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
