Topic: Throwout Bearing Arm (Read 1764 times) previous topic - next topic
I'm installing the T5 that was in a TC in my sport coupe however the Turbo Coupes have hydraulic clutches and I need a cable clutch for the 5.0. I ordered a bell housing from Ebay for the 5.0 however it did not come with a throwout bearing arm. Can I use the throwout bearing from the TC (hydraulic clutch) or are the throwout bearing arms different for the different types of clutches?
They
The 5.0 does use a different clutch fork setup and pedal assembly.
Superbird88, I'm interested in your TC hydraulic setup if you would be willing to sell it.
The Shredder, I'll organize what I have of the TC hydraulic set up and take some pics for you. I think I have everything and its in tact. (Bell Housing - with Throwout Bearing Arm, Dust Shield, Clutch Plate, Pressure Plate, Pedal Assembly, Slave Cylinder and Master Cylinder). The T5 is the only thing I'm keeping from the TC.
Correct me if I am wrong here but I believe a cluch/brake pedal setup out of a 4 cylinder or 5.0 85-93 Mustang will work for you.  Do a search but I am pretty sure it will.
Darren
