Topic: Loss of power during left turns (Read 3948 times) previous topic - next topic
Something I've noticed on my 87 5.0L Tbird is that when turning left, any harder than just a normal easy turn, I lose engine power. It seems to have to do with momentum, as it happens when I make the turn at faster speeds. I could go around a highway bend at 55MPH and punch it, and it just doesn't put out any go. Or, I can take off from a stop and swing a left and midway through the corner, it just coasts, and then regains power. It does this more when there's less fuel in the tank. Does anybody else have this happen?
I'll bet the fuel tank needs to be replaced. There's a reservoir that the pump fits in. It keeps gas from leaving the pump when you turn or accelerate. It's tack welded in, and those welds can give way and the pan starts to move around. I reached under the car and smacked the tank, and could hear the pan moving around.
What Vinnie said , or it could be something as simple as the incorrect fuel strainer on the pump.
The strainer/sock may have come off of the pump as well.
What sucks is the only way to find out is to drop the tank and take a look inside, which is not fun.
I had the exact thing happen to a cutlass I owned and it was the strainer fell off so it's just pulling gas from the small tube... Your lucky though mine would stall.
:ford::oldcougar::mercury:
Sou
I'm sticking with loose baffle.
Sounds like you are low on your left blinker fluid.  Sorry, couldn't resist!
Several have reported similar problems, mine does it on a hard launch and the baffle is in place...
Keep the tank at least half full, problem solved...
Mine starves sometimes, but only when I'm sliding it sideways or doing something with really extreme lateral Gs. I'm gonna have a look in the tank to check on the hose and baffle. I'll report my findings. I should probably take some pictures of the opening I made in the floor of my trunk for quick fuel pump access too, incase anyone else wants to do the same. I highly reccomend it.
Interesting. I never had this problem before having the fuel filter replaced.
I swear, I've had more shiznit on this car broken by a service shop than anything else.
I have the same problem with my daily driver DeVille, whenever it gets below 4 gallons, it will  near stall on right hand turns.  I read somewhere that it was caused by the baffles coming loose over time and making the fuel pump starve on right hand turns.  I just make sure to keep it above 5 gallons and have no issues.
Filter is on the discharge side of the pump so I doubt that has anything to do with it itself.  Fuel pump overheating, soft rubber line between the pump discharge and the hard line leaving the tank, tank has all kinds of  in it and when making a hard turn the fuel sloshes all the debris over the sock, sock is missing, or the baffle is loose.  Either way you chalk it up pulling the tank is about a 1 hour job and if you do it replace the pump, sock, and soft rubber line.
Darren
Quote from: TOM Renzo;369163
Sounds like the connector hose is cracked.....
Yup....been there done that.
That 10 cent piece of rubber hose in the tank gave me fits with my 89 Lincoln MK VII with super low fuel pressure.
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
Also
