Topic: Cam/Heads for Non Roller 5.0 (Read 1648 times) previous topic - next topic
I'm looking for good options for a set of heads and a cam for my Non Roller '84 5.0L. I'm not to familiar with motors and that's why I'm seeking help. I plan to convert to carb and run a 650 or bigger depending on what setup will suit me best. I've got a stock block with 115,200 miles on it, a C4 auto tranny, and a 7.5" rear with 3.73s w/ Trak-Lok. I plan to rebuild the tranny to handle a power gain(it slips anyway)
I need opinions on a setup, links to parts, anything and everything helps. I'm a Collision Tech so numbers on lift and duration are like a foreign language.
you could turn it into a 'clevor' by bolting on a pair of 2v clevland heads with a BOSS 302 intake.. just a thought, there's plenty of info out there on building them
Two biggest factors:
What's your budget?
How much power do you want?
Why not a roller? Especially if you are going to go with a different block.
Why the multiple posts? I thought you were going this way...http://www.foxtbirdcougarforums.com/showthread.php?32217-What-engine-to-build
Quote from: QUICKSHIFT;368718
This post was before I just said screw it to the idea of making more power out of what I have for now. I'm just gonna start a motor build and be done with it. Plus I don't want to sink more money into this motor and ruin an already running vehicle that I can cruise in and have fun. I'll just build a motor and swap them.
