Topic: NO Brakes! (Read 1165 times) previous topic - next topic
NO Brakes!
I was working on my wiring under the hood and now my ABS system does not work. The manual says there is a fuse but I can't seem to locate it. Can anyone help me?
NO Brakes!
So I assume you have an 87-88 Turbo Coupe?
http://www.turbotbird.com/techinfo/TEVES%20II%20ELECTRO-HYDRAULIC%20BRAKING%20SYSTEM%2087-88%20TCs.htm
NO Brakes!
yes 87 turbo coupe
NO Brakes!
87 Fuse panel.
NO Brakes!
There is no fuse for the ABS.
There are two fuse links that are for the ABS.
I am guessing you did not disconnect the battery while working on the wiring.
Did you make sparks?
A yellow wire on the starter relay goes to six fuse links. Four blacks a blue and a brown.
Two of the black links are for the ABS.
Look to see if the one of the link's insulation looks like it overheated. If you can stretch it a little, that means the wire inside has blown.
NO Brakes!
Yes I made sparks. I know I don't know what I was thinking. But the Tech data worked. I had one of the wires in the relay plug out of location so we are back and running and stopping. Thanks for your help I knew it was something simple but without the tech data I would have been up a creek.
