Topic: Wondering if this is a good setup for a turbo setup (Read 2745 times) previous topic - next topic
I have an 87 5.0 cougar that I ordered an on 3 turbo kit for. I bought a set of 3.73 gears for the rear with a posi carrier (stock limited slip unit). I also got a transgo shift kit and a 2600 stall converter. I know that for my 89 turbo t/a everyone recommended a 3500 stall with trans brake, but that made the car drive like a slug on the street. Just curious how does the 2600 feel for daily driving and if I should go for a higher stall converter to build more boost at the starting line.
I am also gonna change the rear shoes and axle bearings (or at least check em).
Are you sitll running the SO if so you will end up melting the pistons fairly quickly as they are not cast
87 TC
your best bet is to find a 5.0 HO, if you don't already have 1.. i'd also recommend finding a set of GT40p heads if you're on a low budget after buying the kit and whatnot, do a little portwork and drop them on with some 3 layer performance 'metal' head gaskets with some ARP bolts or studs.. if you still have the stock SO 5.0 in your car, the heads have a very py flow rate and it won't be long before your pistons are toast
If BOO
I have another 302 that I just tore down, going to go with 331 forged stroker assembly. I have 85 HO heads that have been re-worked, or I might put my patriot aluminum heads on if I decide to go with AFR heads on my race car next year. I am pretty familiar with turbo and forced induction cars I think it'll be ok with 7psi of boost and the stock 9 to 1 compression ratio. The car will be dyno tuned once it is put together, I bought the complete package, so I got the oil filter relocation kit, walbro 255 fuel pump with hot wire kit, upgraded to 42 pound injectors with 76mm MAF sensor calibrated to those injectors. I will have to do a mass air conversion on the car as it is a speed density 5.0. Also I have a rough tune chip for initial startup and break in. This kit is designed to be able to grow into it, once the forged stroker is done and installed I will crank up the boost, but it will stay 7psi until it is ready for it.
Yeah.  Go for it.  7 psi should be fine.  As long as you keep the engine cool.
Then, when you have the 331 ready, turn up the boost to 20psi! :)  Then take a picture of the carnage!
Quote from: TOM Renzo;368218
If BOOST it is going to be substantial i would run Forged Slugs.
I may be wrong on this but i think starting in '87, all S.O. short blocks were the same as the '86 H.O. motors.. Early motors 86-87 had forged slugs. Not 100% on this because i have seen many engines not hold true to this. I really dont know the cutoff from Forged to Cast. But i think it was 88. Ford says the HO is a forged piston engine. Once again i am not 100% on this because i have seen differences over the model years. Either way Forged pistons should be used on a turbo motor for high boost. Hope this helps thank you
NOTE this is from memory and if i am wrong i apologize.
all (original) SO motors i have had my hands into have had the py, flat tops with no valve reliefs(ford's standard, non-cast junk pistons). that's why an SO motor isn't capable of running as large of a cam as a stock HO motor can handle, because the cast HO pistons have valve reliefs
Quote from: canadiancarguy;368223
7-8psi is plenty safe with 9:1 compression, as long as the pistons are at least cast. the compression in my 408 is 8:1 and i'm pushing around 14psi on the street and roughly 16-18psi at the track, depending on conditions
I am not even gonna bother changing the cam or intake on the car, I will put it all on the other long block.
Shadow
Are you running a 351 windsor based 408? Also what size turbo are you running?
yep, but it's a DART block. originally, i had a 58mm garrett on it.. about 2 months ago i found a STEAL on a 72mm precision, so i upgraded.. doesn't spool as quickly, but overall it gives me a much better combo
I have a 302 based dart block in my drag car. They are nice pieces that's for sure. I would like to upgrade to a 460 small block one of these days....
jesus and jiminy crickets a 460 small block? good god almighty
Found this on a ford website.
They are a true flat top with no valve reliefs, and are most certainly forged. They have TRW stamped under the crown. I believe the cast pistons from that year still had valve reliefs.
I was not sure if they were forged but some engines i did were. According to this guy he also says flat tops were forged. I was not 100% on this and still may be wrong. But this guy did confirm they were forged with no eyebrows. Thanks
It has been a long time since i have dun a factory 302. Most of the smaller engines we do are strokers and forged. Hope this helps
I have never seen a factory set of forged pistons on a 302 yet, but  this is the first base model 302 I have ever owned, so not used to seeing such little head ports. Here is another dumb question does anyone make a lower fuel injected 5.0 manifold for cleveland heads?
no intake.. BUT, price motorsports sells intake adapters to bolt a windsor style intake to the boss heads.. sounds like someone's building a clevor lol
http://www.pricemotorsport.com/
