Topic: V8 Tach Search (Read 1952 times) previous topic - next topic
V8 Tach Search
Hello,
I'm looking for a donor tach for my 88 tbird, what years mustang cougar or bird will swap into my 88 tc cluster ? (needs to be for v8)
Preferably with no modding to the housing. I don't mind doing a bit of rewiring. I originally added a resistor to mine to make it read right but when it gets to 5k it sticks now.
V8 Tach Search
'88 Sport and XR-7, I beleive are the only ones.
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
V8 Tach Search
No mustang ones will swap over?
V8 Tach Search
Not without alot of "customizing".
Mike
V8 Tach Search
Just be patient til you can find the right tach. Do it right the first time.
V8 Tach Search
I'm planning on converting the TurboCoupe Tach to V8 by doing the resistor mod...
http://www.coolcats.net/modifying/4to8tach.html
But I also plan to use the boost gauge that is part of it.
V8 Tach Search
I did the resistor mod, now doesn't want to read right 5k range, i'd like to shift it it at 5.5-6k and dont' want to guess. If it comes down to close in price, might just do aftermarket and graft in.
