Topic: I f-up really bad!!!!!!!!!!! Picture update!!!!! 12/22 (Read 10955 times) previous topic - next topic
so finishing up my line lock, I was testing it out when I let it out the car started to roll foward, no big deal till I pressed the gas and brake together dragging the wheels and slamming in to a camaro I bought to sell(oops!!!!) also I now need a new drivers clear parking light
THE CARNAGE:
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Ouch, that sucks. I've got a single clear parking light in the garage. I'll check it and see if it's the drivers side. Are they interchangable by chance?
Quote from: jangus;367574
No but I definitely want it it its the drivers side
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
That sucks...what did it do the the camaro?
That's not "really bad". Smash in the rear quarter....that's bad. You're lucky that it's merely a flesh wound.
Man that sucks beautiful car
2015 Ram 3500 MegaCab Diesel
1986 Thunderbird Elan 302 Crate, x303 heads, e cam, 24lb injectors, gt40 intake, WC T-5, TC rear w/ 3.55 gears, CHP control arms,cobra r wheels.
Quote from: 50tbrd88;367581
nothing much broke the same light and tore the bumper a little
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Quote from: 86sonicbird;367604
was
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Quote from: vinnietbird;367599
That aint no joke.  Before my paint job I let me car roll off some of those car ramps you use to change your oil.  I forgot it was in neutral and it narrowly missed me and slammed into the garage door opening.  Put a pretty decent dent on the quarter panel right below the fuel door.
Definately hurt my pride...I'm just glad I wasn't in between it and the door or I might be 10 toes up right now ;).
Yea could be worse...at least no one was hurt.  I messed up once and had my 93 topaz land in my lap.  I somehow managed to come away without any major injuries.
If you look in my garage you'll see a few little burn outs. Ive never gave it much thought till now. I'm sorry you hurt yours  and I hope I'm smart enough to learn from your mistakes.
Good luck on the search for parts hope to see some more videos from you at the track
Bah thats an easy fix, i did a 65 mustang coupe for a guy 2 years ago, full resto new quarters, floors, ect, the day he brought it home he was backing it off the trailer, thought he put it in gear when it was in neutral and it rolled into a huge tree, smashed the rear body panel, and hit the quarter so hard it was pushed up against the door.  Had to replace that same quarter again, Now that was a big F-up!
So the bird is on it's way back to beauty!!!!!!!!!! I now have to remake the bumper reinforcement.
Before
After
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Looking good so far Jeremy :headbang:
