Topic: Trunk lid tension rods (Read 15143 times) previous topic - next topic
Hi,
Does anybody have a procedure for reinstalling the tension rods that hold the trunk open?  My new cat came with a broom handle to keep the lid up.  I was able to get the rods reinserted in the hinge receivers, but lid still won't stay up.  Any pics would help, too.
Thanks,
Dave
You have to make the tool, it was posted here try using the search to find it.  It's basically a small length of pipe with holes and length of rope or wire... I used 6 gauge wire
Be careful I almost lost my fingers messing with those freaking things
For the trouble, i'd just throw some shocks at it.
Yeah those things are wicked. All i did was lay in my trunk, ad force that thing in! Praying the entire time lol    Those things have alot of tension. When the tension side that holds the hood open snapped, it shut my trunk so hard, i thought someone shot off a 12 guage. Now my trunk lid body lines are actually crooked.
1986 Ford Thunderbird
!!COMPLETED!! 427 ci ROUSH engine swap<<!NEW! Fed by a Holley Terminator EFI setup/ custom COP setup ignition
 8.8 rear. with 4:10 gears, Eaton Trutrac diff, 31 spline axles and external breather system. Had it cleaned, sandblasted, and powder coated.
Holley Terminator EFI with custom made CNP ignition system
"Its kind of like driving the red headed step child of the mustangs" :hick:
I used a 12" long 1" diameter wooden dowel with a notch in it to pop the bar on the passenger side of mine back in the slot. Worked great and I still have all my fingers.
x2 for the 10mm socket/extension. done it many many times on all different kinds of cars.
86 Mustang GT
after getting my fingers stuck in between the rod and the notch I use a small piece of pipe or the socket trick.  I still have all my fingers by the way ;)
I'm going with struts when I get my Sport back. With the additional weight of the modified trunk lid, I think it'll help.
Quote from: jcassity;424003
wonder what happended to master blaster anyway?
still kicking around. been on here just a couple weeks ago.
I know this thread is fairly old, but I'm curious as to how to fasten struts to the trunk? Where do you drill the holes to mount them?
Thanks
Cornfed85
1985 Thunderbird - 3.8 V6, C5  :ford:  :birdsmily:
Send a PM to vinnietbird, he did it to his Sport. :)
