Topic: Guess I need to drain the 8.8 again (Read 1581 times) previous topic - next topic
Having problems with the TC rear's on again off again performance. Sometimes it leaves two nice tracks and just tonight (while I had a friend filming), only the passenger side lit up. I'm hoping I just have to add more friction modifier or something simple. Am I looking at changing the clutches in the diff?
Quote from: Crash225;366729
Probably, that's the only thing that's ever fixed mine when the Traction Lock was weak...
Thanks. Guess I'll bite the bullet and hopefully post a vid worthy of someone's time. Maybe a timeslip??
If the Frictions and steels are ok in the Trac lok you might just need to re shim them.
http://forums.corral.net/forums/general-mustang-tech/1310939-trac-lock-rebuild-weekend-need-info.html  Back when I drag raced the mustang all the time, I used this write up using the alternate clutch pack method, and it always 2 wheel peeled! This alone was worth  few tenths off my 60', which meant quite a few off my ET
(General rule of thumb, .1 off the 60' is roughly .2 off ET :D)
