Topic: '88 tbird eec power relay location (Read 3240 times) previous topic - next topic
Does anyone know where the eec power relay is on an 1988 thunderbird 5.0L please. A schematic would be great if possible.
 Thank you,
  Mike
There's one on the passenger side of the dash, roughly in the area between the glovebox and the EEC....IF that's the one you refer to....
Thanks for the info!
I think mine might be causing a voltage drop to the eec
Im looking for this too. But i cant find it. Any one have a pic of its location.
Behind RH Side Of I/P>>>> If it is a TC it has an IRCM
Yes it is a tc.
For the TC, it's soldered inside the IRCM... Not really replaceable unless you can solder and add wiring to feed a external relay...
If you listen closely, you may hear it click five seconds after you turn the key off.
It has a five second delayed drop out.
