Topic: 4x6 h4 crystal clear headlight conversion (Read 3803 times) previous topic - next topic
what a pain in the but install. I was able to get a 3 pack of relays, from a seabring hard top(only used 2), I had to repin both headlight plugs, and replace the highbeam plug.
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Sweet! Looks fricken nice:D did those sockets I sent you help out? and have you finally got all your interior wiring sorted out?
yes they worked great, actually the wiring looks a little better SEE.............
just waiting to buy a mustang booster so I can finish up the dash
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
oh wow that's still pretty bad man lol
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Those look nice. Also what hood is that? car looks good!
2015 Ram 3500 MegaCab Diesel
1986 Thunderbird Elan 302 Crate, x303 heads, e cam, 24lb injectors, gt40 intake, WC T-5, TC rear w/ 3.55 gears, CHP control arms,cobra r wheels.
Quote from: 86sonicbird;367526
what hood is that?
http://www.carhoods.com/CoverMain%202001.htm
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Where did you get the bulbs for that, and are those lights from any automotive place?
Just the ones off ebay,  they came with the blue bulbs
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
