Topic: O2 extension harness (Read 3369 times) previous topic - next topic
just curious if anyone here has used these and if they are both included in the kit. BBK Performance Extracter Series - O2 Sensor Harness Extensions
http://www.oreillyauto.com/site/c/detail/BBK3/1676.oap?year=1988&make=Ford&model=Mustang&vi=1133929&pt=04651&ppt=C0018
I'm just going to lengthen the wires on my replacement O2 sensors for free. That's a chunk of money in the Sport's world.
If you need new sensors, you can buy them with longer wires.  That is what I did.
Mike
[quot
Tom, what special connectors? Got a link?
mine must not be the good ones then..I just lengthened mine last week
What did you use Jerry? I was thinking about using the regular crimp connectors and shielding over it.
I soldered them, and used shielding... and I had some heat shield tubing that went over all of it near the header
I'll try to solder them. If it doesn't work, I can always crimp them. Thanks.
You can extend the O2 sensor wires in the harness (which I did) but not the wires on the O2 sensor. The wires in the harness are regular wires but the wires on the O2 sensor are special and should not be lengthened. If you do you'll ruin the calibration on the O2 sensor and it will not function properly.
Hmmmm, I never thought of that. Lengthening the harness is easy enough. Yes, I'll do it !!! Tomorrow.
I made extension harnesses out of old sensors and part of the cars harness from the junkyard
Well i
I'll pull the harness tomorrow,. That's an easy task. I'll first  install the replacement O2 sensors and see how much wire needs to be added to the harness, then, make it happen.
