Topic: computer swap (Read 3944 times) previous topic - next topic
computer swap
what do i have to do in order to swap out my stock computer in my 5.0 tbird  and put in a mustang computer so i can buy a computer chip for it.
what year does the model of the mustang does it have to be and were is the computer located at in the car
Re: computer swap
This thread makes baby Jesus cry...
Re: computer swap
Don't waste your money....
Re: computer swap
why  and were is the computer located in the car
Re: computer swap
Ancient chineese secret!
HAHAHAHAHAHAHAHAHA.
Re: computer swap
One day, the Grasshopper will be able to take the stone from my hand, but it will not be this day.
While your looking for that, maybe you can find the switch that makes you ask ridiculous questions over and over again and shut it off......
Re: computer swap
aqaaaaaahhh  take the balls out your mouth
Re: computer swap
IBTL.
(that's In Before The Lock)
I say for the second time this hour: :locked: :locked: :locked:
Re: computer swap
To answer your question (again), to use the Mustang computer you must either use a Mustang engine or convert your existing engine to Mustang specs (heads, cam, injectors, intakes, throttle body, etc). The Mustang computer WILL NOT work with your current engine. The cam, injectors and firing order are all incompatible. And a "chip" will not net you any measurable power on an otherwise stock engine anyway. Chips are best used to get the most out of modded engines.
Re: computer swap
Surprise!  I KNOW that I am not the only one who wants to see this person never post again..... :locked:  :locked:  :locked:  :locked:
Re: computer swap
Quote from: Paul Flockhart
I can't comment too much.. I know a few people would love to see me never post again, too. :p
Re: computer swap
all u talk is bullshiznit
Re: computer swap
BS huh?  These 2 threads are both started by you and ask the same thing.....
http://www.foxtbirdcougarforums.com/showthread.php?t=2247
Oh look! So are these 2.......
http://www.foxtbirdcougarforums.com/showthread.php?t=2564
http://www.foxtbirdcougarforums.com/showthread.php?t=3205
