Topic: Weird Tick after timing belt changed. (Read 1651 times) previous topic - next topic
I am sure Cam/crank/aux timing correct, checked and rechecked!
Tick did go away, but Not sure why it was there in the first place. Oil pressure also good. I also caught the intermittent cutting out problem on video.
[video=youtube;pEee3j3oGMo]http://www.youtube.com/watch?v=pEee3j3oGMo&feature=youtu.be[/video]
Something in your valve train.  After my timing belt broke I had a broken HLA (Lifter).  I actually had 2 of them broken, just one was broken completely in half down in the head.  I would strongly suggest you go ahead and check everything under that cam cover.  It's a good time to upgrade to a Boport 1.1 cam or, at the very least, do a ranger roller swap.  You can pick up the reconditioned roller Followers from Boport and the cam from Autozone.  The Ranger cam takes a bit off the top end and puts it all down stairs, but, with a little tweaking on the timing you can get a good bit of the power back.  The ranger cam is smaller but the Bo-Port 1.1 cam will give you about 15 horses over the stock cam, the wide band HLA's will keep everything smooth and with it being a roller cam, no more metal being shaved in your engine.  The cam will probably out live the car at that point.  Those ticks from the valve train can take a toll on your power band and your engine as a whole.
1987 Thunderbird Turbo Coupe (daily driver) - T5, Short Throw, Ranger roller cam (soon to be Boport 1.5), stock turbo and TMIC (also soon to change.)
Some Time relenty fail Connectors
I agree with the lifter tick.
I just purchased Boport's 1.9 cam and am going to double check everything when I install it.
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
1988 Turbo Coupe (RIP)
