Topic: Upcoming DIY project (Read 3262 times) previous topic - next topic
I'm currently gathering supplies and information required to do custom led tail/marker lights.  Depending on the outcome, trouble and price of materials I may be willing to do it again for a price.  My goal is to look stock till the lights are on.  I am also pondering custom headlights for 4-eyed vehicles in the future.
I'm interested in seeng the results. Post pics of the before, during, and after.
oh I will...I plan on making it as close to a tutorial as possible.  Also depending on the size the led boards end up being I could offer them for a price and have they buyer install them.  I'm looking at getting 300 5mm leds and resistors just for on set, any extra's will be used on my third brake light and maybe even the front turn signals.
going to integrate sequencing into them while you're at it?
Haven't decided if I like sequential tails yet...but I'll look into making it possible.
I'm hoping the end result will be something that anyone could easily add to their car with little to no modification.
I keep picturing these:
[video=youtube;K6sZg3iL5EY]http://www.youtube.com/watch?v=K6sZg3iL5EY[/video]
Well that is impressive, but a bit over the top imo.  Not that thats a bad thing, just not my style.  I do however like the basic sequential tail lights.
Research has turned up some interesting stuff.  The configuration(what appear to be 3 bulbs, outer being turn signal, middle and inner being a blend of brake/tail) I was hoping to go for will require a lot of the same wiring as sequential tails anyways.  So I'm going to make a "virtual" mock up using photoshop before I make a solid decision on led pattern.
are you going to include a white section to serve as backup lights?
Yes, all the lights in the rear will be led.  I've got measurement, just trying to find a breadboard the proper size.  I'm almost tempted to use plastic needle point canvas doubled up and glued together but don't know how well it would stand up to any heat generated by the leds or resisters.
The LED's and resistors shouldn't generate any heat at all, at least not anything measurable. I had started my own custom LED tail light project years ago for the 87/88 style. I was going to use 300 red LED's (50 per circle, 3 circles per side) and 200 white ones (100 for each backup light). I was using the stock housings and lenses, including the inner red lenses with the red parts cut out. I got one light about half finished and lost interest, and now I don't even have the car anymore.
Some pics (may give you some ideas for your project):
X
X
X
X
Here was my original concept drawing - obviously the actual project differed slightly
X
A tip, if you're doing this: Solder the LED's to the board about 1/8" from the surface, and make sure the legs are all oriented horizontally. This is because the boards will not be mounted vertically (the rear of the car is angled) and the 1/8" will allow you to bend the LED's down so that they face straight backward when installed in the car.
I also did (and actually finished) some LED's for the front lights. These ones were really cool - they lit up amber for park lights but turned white for turn signals:
Park:
X
Turn: (the light was actually much brighter than shown, my camera just couldn't capture it)
X
Without the lens on:
X
how did you get away with white lights? Here the turn signals have to be amber by law.
Oh and here's what I was thinking for your board.... I don't know if the birds have them but at least the cougars have this reflector thingy behind the actual lenses and maybe you could pull that out and use it for you LED board... just a thought
