Topic: Fuse diagram (Read 1235 times) previous topic - next topic
Fuse diagram
can anyone post the fuse diagram?
My door unlock/lock, radio, and interior light(the one in center of the roof/headliner) are not working all of a sudden since I replaced the headliner.
Fuse diagram
Check the harness above the headliner. Mine did the same thing when I was messing around with the headliner down. Ended up burning a hole in my fuse box....literally. Do you have an owner's manual?  I think I have one for an '86 in my bedside table (I have no idea why). I can mail it to you if you need it.
Fuse diagram
Oh, I believe it's fuse 13.It's a 5 amp fuse right in the middle of the outer edge on the right (inner) side of the block.
Fuse diagram
Quote from: vinnietbird;365547
Im working on my 87. I should have specified
Fuse diagram
By the way, how is your A/C problem?
Also by the way, fuses are designed so they can be quickly checked without pulling them out.
They have a little metal spot on each end of the top.
Turn the key on and touch the spots with a test light. Lights on both sides it's good. Only lights on one side it's bad.
Fuse diagram
Thanks Vinnie and softouch. I am going to figure it out tomorrow.
Softouch, I havent fixed the AC issue yet because I figured I would put in a new WOT/AC fan relay first, to see if that would fix the problem. Well, IT DIDNT, so I'm going to splice that wire tomorrow and see what happens. Wish me luck
