Topic: Electronic Climate Control light bulb part # (Read 1231 times) previous topic - next topic
Does anyone happen to know what the part number is for the light bulbs in the Electronic Climate Control unit? One of mine went out and I need a new one. I tried swaping in a bulb from another unit I have and it turns out both of those bulbs are burned out as well (it's the bulbs not the unit as I can swap the good bulb side to side and it works fine.).
I figured it would have markings on it, or the base??
Mike
Whatza matta wit you boy, ain't got no smartz??? Those modules clearly state... "No User Components Inside"
No I never pay attention to those labels either... The bulb you need is #37, also used in the Systems Monitor, and factory radio... Replace both or you'll be back inside again in a month or two...
Quote from: mcb82gt;365427
If they did at one time they don't after 23+ years.
Quote from: TurboCoupe50;365430
This thing has been out of warranty for 18+ year so I figure there is no harm in opening it up. I'll go get some #37 bulbs and be done with it. Thanks.
Hell according to the emissions label the idle is not adjustable. That's a lie....
